Lenovo ThinkPad T480/T480s
This page describes how to run coreboot on the Lenovo ThinkPad T480/T480s.
Important Notes
EC UART
The T480 (but not T480s) supports the use of the EC UART for debugging. If you want to use this feature, you need to downgrade the vendor firmware to a version with a compatible EC firmware before flashing for the EC UART to work properly. The EC firmware version needs to be 1.22 (N24HT37W), which means any BIOS from 1.39 (N24ET64W) to 1.54 (N24ET79W) is acceptable.
The mapping can be seen here on Lenovo’s site.
Bootguard
The T480/T480s both have Intel Bootguard enabled, which prevents the device from running firmware which is not cryptographically signed using the manufacturer’s key.
The deguard utility will need to be used in order to bypass Bootguard on these devices.
Thunderbolt
Older versions of Thunderbolt 3 controller firmware are buggy on these laptops.
The issue is that the TB3 firmware writes its logging data to the TB3’s own 4M flash chip, and when the flash chip fills up, the device fails to boot.
Lenovo has addressed this in a TB3 firmware update, which is recommended be be applied before installing coreboot to ensure long-term reliability of the device. That said, most laptops that still work likely have this fix already applied, and you can always externally flash the TB3 firmware update at the same time as flashing coreboot.
If your device becomes bricked due to this issue, the only resolution is to externally flash the updated/fixed TB3 firmware flash (which is located on a separate flash IC from the main firmware).
The Lenovo TB3 FW update can be obtained from Lenovo’s site.
The Libreboot project has some more information about the issue and how to externally flash the TB3 firmware.
Initial Setup
Follow the coreboot tutorial to:
install dependencies/prerequisites
clone the coreboot repo
build the coreboot toolchain
You will also need to clone the deguard repository, in order to bypass BootGuard.
Required proprietary blobs
When flashing the T480/T480s for the first time, the following blobs are required for a full flash image:
Flash Descriptor (IFD)
Management Engine (ME)
Gigabit Ethernet (GBE)
These will either be extracted from the vendor firmware on the device or downloaded as needed.
Additionally, the T480/T480s make use of Intel’s Firmware Support Package (FSP) for memory and silicon init. FSP is provided by default as part of the coreboot build, no user intervention is required.
Reading the vendor firmware
The T480/T480s have a single flash chip, a 16 MiB W25Q128 in a SOIC-8 package. The flash chip uses the following layout:
00000000:00000fff flash descriptor (fd)
00fff000:00000fff platform data (unused)
00001000:00002fff gbe
00003000:006fffff me
00700000:00ffffff bios
To read the vendor firmware, disconnect external power and remove the back of the laptop according to the T480 Hardware Maintenance Manual. Disconnect/remove the battery (and CMOS battery if equipped). Attach a chip clip to the flash. Use an external programmer (ch341a, raspberry Pi, etc) and flashrom to read the chip.
Preparing the binaries
The IFD and GBE need to be extracted from the vendor firmware backup read from the flash chip.
See Extract IFD binaries.
Rename the extracted files to ifd.bin and gbe.bin and move them to the binaries folder
you created per the instructions.
Preparing the ME with deguard
Please review the documentation on the use of the deguard utility.
Since the T480/T480s is already a supported target, we simply need to download/extract the donor image, then generate the “deguarded” ME firmware image
The donor ME binary required for use with the deguard utility can be downloaded as part of the Dell firmware updater. After downloading, use Dell_PFS_Extract.py to extract the required ME firmware image from the updater:
python Dell_PFS_Extract.py Inspiron_5468_1.3.0.exe
The resulting binary should be renamed me_donor.bin and moved to the binaries folder with
the IFD and GBE.
Then, generate the deguarded ME firmware image:
./finalimage.py --delta data/delta/thinkpad_t480 --version 11.6.0.1126 --pch LP --sku 2M --fake-fpfs data/fpfs/zero --input ../coreboot/binaries/me_donor.bin --output ../coreboot/binaries/me_deguarded.bin
The command above assumes you are running deguard from the root of the deguard repo, that the
deguard and coreboot repos are checked out under the same parent directory, and that your ME
donor firmware is in the binaries subdirectory of coreboot (along with the IFD/GBE binaries).
Adjust the paths as necessary if that is not the case.
Preparing the IFD
In order to use the modified ME firmware binary generated by deguard above, we need to set the
HAP bit in the IFD using ifdtool:
util/ifdtool/ifdtool -p sklkbl -M 1 binaries/ifd.bin
The modified IFD will be saved as ifd.bin.new. Rename the original file to ifd.bin.orig and
the HAP-enabled one to ifd.bin
Building coreboot
You can use make menuconfig or make nconfig to select the mainboard (Lenovo T480 or T480s),
enable the inclusion of the IFD/ME/GBE binaries, and select your payload and options.
You can also just use the following defconfig:
CONFIG_VENDOR_LENOVO=y
CONFIG_IFD_BIN_PATH="binaries/ifd.bin"
CONFIG_ME_BIN_PATH="binaries/me_deguarded.bin"
CONFIG_GBE_BIN_PATH="binaries/gbe.bin"
CONFIG_HAVE_IFD_BIN=y
CONFIG_BOARD_LENOVO_T480=y
CONFIG_HAVE_ME_BIN=y
CONFIG_HAVE_GBE_BIN=y
CONFIG_PAYLOAD_EDK2=y
Save the above to a file called defconfig in your coreboot directory, then run:
make defconfig
make -j"$(nproc)"
Upon successful compilation, you will have a file coreboot.rom in the build directory ready
to flash.
Flashing instructions
The initial flash of coreboot with the modified IFD and deguarded ME must be done using an external programmer:
sudo flashrom -p <programmer> -w coreboot.rom
Subsequent flashes can be done internally and need only modify the bios region of the flash:
sudo flashrom -p internal -w coreboot.rom --ifd -i bios -N
The coreboot.rom flashed on subsequent flashes does not need to contain the IFD/ME/GBE
binaries if only flashing the bios region.
Known Issues
Alpine Ridge Thunderbolt 3 controller does not work
Lower (right) USB-C port only works for charging/DP alt mode, not USB/PCIe data
Some Fn+F{1-12} keys aren’t handled correctly
Nvidia dGPU is finicky
Needs option ROM
Power enable code is buggy
Proprietary driver does not work at all
Nouveau only works on linux 6.8-6.9
Headphone jack detection
Both headphone jack and speakers work when manually selected via pulseaudio
Verified Working
Integrated graphics init with libgfxinit
video output: internal (eDP), miniDP
ACPI support
keyboard and trackpoint
SATA
M.2 SATA SSD
NVMe
USB
Ethernet
WLAN
WWAN
Bluetooth
Virtualization: VT-x and VT-d
Internal flashing (after initial flash with unlocked IFD)
